Unstable on heavy braking
Howdy,
Sorry for another thread but being new to Honda, the s2000, vtec and rwd I have a few things to ask.
When braking sharply or hard from speed the rear end on my car dances around from side to side like its about to swap ends with the front, it's quite unnerving and being a track day person would like to put it right.
I know the rear strut brace is a a little bent so am replacing this when I can find one ( it isn't too bad)
What else could cause this, the car has ds2500 front and rear, I would say the car pulls to the left when doing this too.
Anybody have any experience?
Thanks
Ross
Edit, the car is a well looked after one from this very forum and the geo was done very recently
Thanks
Ross
Feel the wheel temperatures after a good run, if one is hotter than the others you have a sticky caliper. Same goes for tyre temps ... if one is hotter in one part than the other side, Geo will be out or tyre pressures are out.
Tyres are easy to check
Geo can be checked Wheels in Motion have opened up in MK
quick brake check could be done by a garage that does MOT's. Get them to put it on the brake tester and they will be able to work out whether each brake is working correctly. Personally i have found the when the front sliders are seized or sticky you get a brake pull in the direction of the faulty brake. Requires regreasing of the sliders to ensure they are free.
When i first got my S2K it had bad brake pull and after stamping on the brake on a clear road and getting the ABS to come on it freed up the brakes. I still changed the discs and pads later on but it sorted out my issue for a while
The condition of the brake caliper sliders is important!
Posts on the US forum suggest that, if the car is a daily drive, the sliders should be cleaned and regreased at least once a year.
Gentlemen, first time i have taken the car out in anger today and it didnt take me long to work out that my driver side front and possibly rear calipers are sticking.....
hopefully take apart and lube up etc.
Also think i need my shocks rebuilding where would i have that done for blistein coilovers ?
Cheers
Ross
Cheers
Ross
UK Moderator
Balance Motorsport do rebuilds http://www.balancemotorsport.co.uk/p...bers+(Dampers)
Or try these guys http://www.classicheroes.co.uk/servi...ilding-service
or try Bilstein's distributors
KBSS Ltd, Unit 3, Swannington Road, Broughton Abbey, Leicestershire, LE9 6TU. Tel:01455283407
Mines the same, all over the place on heavy braking! A bit scary!
Also, what's the front/rear braking percentage on our cars? I know on front wheel drive it's normally like 80:20?
