UK Fog Light & S/W, JDM Car
I have a JDM S with UK rear bumper + fog light (fitted) and a UK fog light switch that I'd like to fit and get working as per UK cars. My current setup uses a two way s/w with LED...it looks naff so I have bought a UK switch.
I've searched and not found a great deal to be useful, other than that I require a relay too...which I'll probably get from GarageR.
Does anyone have a wiring diagram that they can draw/provide for me, especially as the switch has no pin identifiers please?
I have the service manual, which is of no help as it's for the USDM
Any assistance appreciated
Yes, it's a s/w, but it needs a relay as it does not stay closed.
I could get the fluke out, but wondered if anyone knew the required info to save me some time
Lofty - why not check the wires on a working car You have access to at least one that i know of.
Then you pop off to Honda and buy the plug
Then you wire it in
Then you wire it in
Thanks for the link Dave, if only the component values were supplied too
http://www.the12volt.com/installbay/forum_...s.asp~TID~68824
Have a look there for some stuff which might help you exclude some stuff ....
Can only find a JDM wiring manual that has ..... NO FOG SWITCH. Only switch in that location is the cruise control one.
MPoxon
02-27-2023 09:43 AM
AndyDoh
10-10-2002 04:18 AM
