Tyres
Tyres
Hi, sorry to ask about tyres, I know it's covered in the FAQs but as I live in Switzerland and have just been bombarded with several tyre offers I wondered if someone could confirm if any of these are the correct tyres.
Bridgestone:
Front: Bridgestone 205/55 R 16 89 W S-02 TL
Rear: Bridgestone 225/50 R 16 92 W S-02 TL
Eagle F1:
Front option 1: Goodyear 205/55 R 16 91 W Eagle F1 GS-D3 TL
Front option 2: Goodyear 205/55 R 16 91 W Eagle NCT-5 TL
Rear: Goodyear 245/45 ZR 16 Eagle F1 TL
Presumably the Goodyear option 2 is wrong because they're not "F1", but what about the option 1 fronts, they don't have "Z" as part of the name - is that the correct tyre?
The F1s are about
Bridgestone:
Eagle F1:
The F1s are about
Originally Posted by psirac,Aug 23 2004, 07:29 AM
Eagle F1:
The only tyres that Goodyear make in suitable sizes for 16" wheels on the S2000 is the GS-D2.
Which is a pity cause I think the GS-D3 is a better tyre.
https://www.s2ki.com/forums/index.php?showt...0&#entry4243401
See the above link for a picture of the OEM Bridgestone S-02 tyres (there are different types of S-02 made and the S2000 versions have ES02JZ on the sidewall). Make sure you get the right S-02's as other S-02's will give too small a footprint on the road.
If you are buying any other sort or make of tyre, the rear's will need to be 245 width not 225 width (as the S2000 S-02's actually give a 245 width fitted).
More than that I can't really comment apart from saying that in my opinion if you want a better wet weather tyre Bridgestone S-03's are really good and I would think (I don't know for sure but I strongly suspect this) give a lot more dry grip than F1's.
Thanks both, I'll go with the Bridgestones then. I did stress about the ES02JZ type being very important but I'm going to send them the pic that you linked as well, just to make sure!
Thanks again
Simon
Thanks again
Simon
