Tyre Pressures And Road Tests
Old 07-16-2004, 10:38 AM
mikey k's Avatar
Spill the beans!!
Whats this "device"
Old 07-17-2004, 03:10 PM
Amuse Boy's Avatar
Originally Posted by Neil.H,Jul 16 2004, 02:50 PM
From my experience the pressures vary according to how hot the tyres are, usually they read higher (~1 psi) when warm, this is from using the same gauge before and after a run.
I wouldn't worry too much about 1 psi difference, I very much doubt you would notice that. I think the temperature of the rubber makes a much bigger difference.
You obviously aren't driving the car right. I start a drive with 32 all round and finish with around 34.5 / 35 psi all round.
I use the digital tyre pressure gauge from Halfords - IIRC it has an error margin of +- 0.5 psi
Different pressures between left and right tyres make a big difference - braking can make the car squirm and spirited cornering can be a little entertaining. IMO
Old 07-17-2004, 03:23 PM
Neil.H's Avatar
Don't lie, everyone knows your car never moves
That was off the top of my head, I guess I remembered wrong. I use the Halfords gauge as well, I agree that different pressures could throw the handling off but I think 1 psi is too small a difference to notice. /shrugs
Old 07-17-2004, 04:06 PM
Amuse Boy's Avatar
1psi between wheels is definitely noticeable - try a brake test - 100 down to 10 mph and you'll notice the car squirm with uneven pressures.
Old 07-17-2004, 04:54 PM
Kobe's Avatar
the point is to be consistent....use the same gauge and measure at equivalent temps. If you can read the gauge to 1psi..then it should be able to done on all tyres with good accuracy..as long as you don't leak too much air whilst doing it.
I use compressor and then bleed the air to the point I want...use a gauge that holds the max pressure so easier to read away from the tyre.
I always notice the difference after taking the car to the dealer for a service..since they invariably play with the pressures.
The absolute number is not so important...it is what you are used to and you adapt your driving to that, it's the differences that cause the problem.
Old 07-18-2004, 07:42 AM
honpar's Avatar
I think theres a few more variables to take into consideration here, can't all be put down to 1 psi differance across the axle, road surface, heaviness of braking, transfer of weight all come into play. Go to a tyre fitters and ask if they have a recently calibrated pressure gauge and compare yours against it, at least that way you will know how much adjustment is needed when checking pressures.
Old 07-18-2004, 09:11 AM
mikey k's Avatar
kobe is spot on - be consistent!
PS I use the 0.5 psi step helfords gauge as well!
Old 07-18-2004, 10:46 PM
Karl2k's Avatar
Any comments on the Nitrogen option in tyres?
Filling the tyres with nitrogen (I.e. pure air) is supposed to give better consistency. Basically (as I was told whilst have a 4 wheel geometry setting session done on Saturday) it is the water molecules in air that expand / contract when tyre temperatures rises/falls. Without the water molecules, there are no changes in tyre pressure...
Anyone gone for this? garage I was at on Saturday
Zebadee
07-30-2010 01:09 PM
dbzerk
15
04-03-2005 08:36 PM
tomthumm
03-10-2005 01:17 AM
euan
08-13-2003 01:53 AM
Dracoro
12-23-2002 03:33 AM
Quick Reply: Tyre Pressures And Road Tests
