Tyre pressures
Old 06-20-2005 | 11:50 AM
JamieS2K's Avatar
Default Tyre pressures
Put 32 in mine a few weeks back and noticed this last weekend it was a bit bouncy a high speeds. Forgot to take the readings but as it was 91 degrees here for 2 days, would that effect the pressure bearing in mind air expands in heat
Old 06-20-2005 | 11:55 AM
jasond79's Avatar
What should the tyre pressures be ? (noth back and front )
Old 06-20-2005 | 11:56 AM
JamieS2K's Avatar
Mine are 32psi but some people like 34psi
Old 06-20-2005 | 11:59 AM
rahula's Avatar
ambient temp do affect tyre pressures and I posted about this in my Europe tour thread. I would adjust them back to 32 on a cold reading. I am no expert about this but it made sense to me when away and it worked as my car was exactly as you described it.
Old 06-20-2005 | 01:57 PM
robs_silver_s2k's Avatar
ambient temp makes a big difference
Old 06-20-2005 | 09:51 PM
Asterix's Avatar
I don't have "cold" readings as such. The ambient temperature is high at the moment - in the 40s - and as the tarmac can fry an egg, the shortest of journeys heats the tyres up tons.
So... at the nearest garage a couple of Ks away I put 36 fronts & 38 rears (Michelins). Seems fine.
Old 06-21-2005 | 12:07 AM
MLC-PM's Avatar
I also noticed this at the weekend.
Did the usual checks, and noticed they were 34 all round, where as I always run them at 32. Ambient temperature has quite an effect.
Old 06-21-2005 | 03:26 AM
S2kSi's Avatar
I was thinking this the other day when adjusting the pressures on my S.
I run Goodyear Eagle F1s and generally run them at 34psi cold (to counter the slightly softer sidewall).
After a pretty quick run last Friday (it was scorching in the SE), I stopped at my local Shell garage and checked them using their pump/gauge and they were reading ~ 40psi!
Is there a generally accepted correct ambient temperature when manufacturers are quoting tyre pressures?
Surely there's a market for a pressure gauge that measure the temp of the air too and adjusts accordingly?
Old 06-21-2005 | 07:00 AM
Asterix's Avatar
You'd also have to measure the humidity and make up of the air within the tyre.
Zebadee
07-30-2010 01:09 PM
wingnutLP
01-29-2006 11:56 PM
euan
08-13-2003 01:53 AM
Dracoro
12-23-2002 03:33 AM
DavidM
01-04-2001 05:27 AM
Quick Reply: Tyre pressures
