Two fans
Two fans
The two fans behind the radiator, whats the one on the right (as you look face on at the car) for?
The fan is loose and I dont think its spinning properly, likely cause? easy fix??
Thanks
Rob
Thanks
Rob
Air conditioning is working fine but think your right it is the AC fan.
Any ideas why it might be loose or the best way to remove it to fix/replace it?
1 Post
Just to confirm Gav is correct.
When you say it's loose, do you mean just the fan or the whole unit?
The unit is attached at three points, two at the top and one at the bottom. If it's the whole unit, I'm guessing one of these has come adrift.
