Turbo Boxster!!
Turbo Boxster!!
http://cgi.ebay.com/ebaymotors/ws/eBayISAP...item=2475466489
Found the above on boxanet.
$50K seems a pretty good price!
Originally posted by san2000
.....but 0-150,000RPM in 0.7 secs?
Typo?
or windup?
Typo?
or windup?
Phew!
(......does a turbo really spin that fast!!!!?)
Phew!
Definitely a wind up, i used to have GTT F1 Hybrid Turbo fitted to a Renault 5 GT Turbo and that only wound up to 60,000 rpm and that could put out 60 psi easy (not that the engine could take that). A turbo which span to 150,000 would either have very shallow blades or be a wind up (They usually test Turbo's to 130,000rpm).
Second thing, there would be no point in putting twin turbo's on a car with an in line 6 cylinder engine, twin turbo's are for V engines with two inlet and exhaust manifolds.
I think the only way we will know for sure is if we all club together and buy it.
Andy
Andy
[QUOTE]Originally posted by AGW
The Porsche Boxter is a flat 6 (Boxer Engine), it is easier typically to use 2 smaller turbos than one big one (space problems)
If you look at the Garret MAPS you will see that for a the smaller frame GT series fairly High RPM's are achieved, even a GT30R can do 120K+
On this link you will see that the IHI RFH3 turbo's max speed is 250 000 RPM
http://www.ihi-turbo.com/turbo_RHE-RHF.htm
The fact that they say "self lubricating, variable geometry turbo's" implies that they are possibly using Aerocharger VATN units (which I thought were out of production ?).
-- Paul
-- Paul
