at the track now, please help asap. Smoke coming out the back on high rpm changes
What do you mean trimming your signature?
MB's right, and the more i think about the more its been overfilled.
If i were you, i think i'd called it a day, wait till it cools down and drain some if you have the tools, you could undue the filter but oil will be everywhere and it will be red hot.
Member
If you can get the car jacked up and crack a touch of oil from the drain bolt, that will do it. Clearly it will be hot, and don't overtighten that bolt either.
You can drain it from the sump bolt from the top if you're careful to 1. not drop the plug and 2. not burn yourself on the exhaust and then 3. drop the plug anyway.
My guess it's oil slop with a bit too much oil and getting sucked into the PCV system although i thought they changed the PCV design on the facelift cars to prevent exactly this.
