Throttle Cable.
#21
OMG!!
Mine really was bad, it goes like a fecking rocket ship now.
I can only assume that the throttle never opened fully with so much slack in the cable.
#22
I am actually quite worried about how fast and light the car now feels.
It seems to take a lot of braking now. I have looked at the idle revs and they seem quite normal.
Re-measured the slack properly pushing it down from the centre and its about 5mm.
Like you i cant believe the throttle ever opened properly outside of vtec.
#25
Never known one to snap. I've had three very low mileage S's with throttle cables and they all come from the factory this lose. The tech manual also states a lot of play IIRC.
#27
Originally Posted by ukphil78,Apr 11 2007, 11:46 AM
What happens if/when you run out of room to tighten?
The other end of the cable (down deep in the footwell) has a large alloy button on the end about 1cm across, position the spacer under this.
I used a felt washer 7mm thick ( Dremel felt polishing wheel )cut a slot through to the central hole and pushed the cable through to the centre of the washer.
Small cable tie around the circumference to stop it coming off (trial & error on my part )and you have gained 7mm at the other end for adjustment
