Thoughts on front upper and lower bracing
#22
Originally Posted by chilled,Jul 25 2006, 01:52 PM
that could well be the cause of Craigs snappy rear then.
#24
Also thinking of adding some braces, so what is the conclusion on the
rear lower arm? Anyone know does it make breakaway more or less progresive?
Thinking of the Cusco lower arm and maybe front strut brace too.
Russ.
Russ.
#25
Don't think the rear really changes the breakaway - that's geometry.
The extra rigidity allows one to sense it earlier and the car is less skittish on really bumpy corners.
My car is an original Honda S2000, Mikey's is something a bit different, which might explain his different experiences.
#29
Originally Posted by lucky77,Jul 24 2006, 06:42 PM
#30
Here's a link to the photo of the bar I think I'm after:
https://www.s2ki.com/forums/index.php?showt...dpost&p=5619708
EDIT: but if you look at the packaging at the top of the GB thread then you'll see the part number on the bar (in the second photo) which appears to match up with the number Stevie emailed me I wonder if the photos of the blue bar which appears to tie the suspension arm bolts together is just a generic photo which doesn't reflect the rear bar for the S2000?
