Theoretical Top Speed
Administrator
http://www.mysportscar.com/tools/topspeed.htm
Sounds like fun, but i dont know the gear ratio thing.
Discuss
Discuss
You might want to try this instead:
The Reverend's Gear Calculator
Includes the S2000 info (and does all the gears).
Oh, and bear in mind that a stock S2000 doesn't have enough power to hit the limiter in 6th.
Very useful site for anyone thinking about changing the final drive ratio as well.
-Brian.
-Brian.
-Brian.
-Brian.
The 4.57 from Ricks (http://www.ricks2k.com/products/reargears.php) looks interesting.
A very comprehensive reply Brian - does the coy imply that you're expecting one in January ? This is a mod which I'm considering, so would be very interested in any impressions.
Do you think that changing the manifold makes that much difference (hype aside) ? If so, which would you consider ? Is the performance gain due to the manifold being longer / less restrictive ?
REDS2KCA
06-03-2004 02:32 PM
