Technical FAQ 2.0
#61
Neil,
Great bits of advice and help.
Just one thing, the link to the Alarm manual seems to be offline, could you please post a new link to the pdf?
By the way, just had my immobiliser replaced, pain in the a se, the dealer took in 2 large fobs, and replaced them with 1 small one.
The small one is better (obviously smaller) but don't have a second, is this correct, or should I have been given a 2nd?
Sun's out, roof's down (sorry gone smile happy)
#62
I'm looking at the link now, thanks for the heads up!
You should have two key fobs, what happens if you drop one? Go back to your dealer and play hell
#64
RE: bench tested VTEC
Unless migzy is popping up to sunny East Anglia, then it looks like a lot of the dealers
say that, because the S2k is bench-tested, you can push it as soon as you like.
I asked the same question about running in the new MY04 2k of John Banks Bury, and the salesperson said exactly the same: the bench testing means it's okay to VTEC from the word go.
Is it worth putting a word or two in the tech FAQ? or should we just let people RTFM?
#66
Yep, now that I have a manual I can see that it says to run in for 1000km or 600 miles (which is only 960km - so I'm sticking to miles )
Mine MY03 (Silly, so prolly a MY02).
#67
#69
Administrator
oi neil not sure if this is right but we should get the right one in the faq
https://www.s2ki.com/forums/index.php?showtopic=258031
#70
Administrator
A Super thread from Nigel:
https://www.s2ki.com/forums/index.php?showtopic=262101
Suspension Wishbone & rear control arm bushes corrosion
