Synchromesh on 2nd gear
Old 01-22-2009, 02:14 AM
  #21
Jonsey Boy!'s Avatar
Originally Posted by Rew' date='Jan 21 2009, 09:17 PM
In the currrent climate i am surprised they turned the work away. If you have a search on here then you will see others have done this done foc. I can't see how they can dismiss something that is an intermitant fault, Very little chance they will replicate this. I would call another honda dealer with your chassis number and see if they can check against honda Uk. That's what my dealer did.
Apparently it's a faulty batch of gearboxes fitted to a range of cars identified via the chassi number. mine was smack in the middle of the production run.
honda UK are aware of this!
Mine did this the other day I thought it was my imagination, my car is just out of it's 3 year warranty period, is it a warranty job or a recall?
My question is will they still sort it?
Old 01-22-2009, 04:44 AM
  #22
smiffy555's Avatar
Great reply Ian_6301 - thanks.
As a service requirement according to the Honda schedule, what age / mileage should the gearbox oil be replaced? I've never seen or had this done to any of my cars.
They always seem to be very tuned into recommending brake fluid replacement every 2 years but not g/box oil.
Old 01-22-2009, 01:21 PM
  #23
m1bjr's Avatar
The diff is about 27k, but the box far higher, like 70k or something?
Yes, the box plug has a magnetic tip.
Old 01-22-2009, 01:42 PM
  #24
Putney's Avatar
my old MY00 would crunch when cold... also 1st was stiff to engage... I had a new clutch, pressure plate and release bearings i think.. it came in at
Old 01-22-2009, 02:46 PM
  #25
plastic91's Avatar
Mine is also difficult to get into 2nd gear when cold, but i don't think you have any issues when it's smooth after warning up. Just skip 2nd gear, which is what i usually do.
Old 01-23-2009, 09:28 AM
  #26
Administrator
AquilaEagle's Avatar
Mine does this, but I just live with it
Old 01-23-2009, 10:26 AM
  #27
Rew
Rew's Avatar
As far as I am aware it has not been done as a recall but dealers have had a bullitin advising them of the problem. Would have thought it would still be done if out of warrenty as they are admitting it has been afault on certain cars from manufacture
Old 01-23-2009, 10:45 AM
  #28
blue monster's Avatar
[QUOTE] Rew Posted on Jan 23 2009, 07:26 PM
Ebi17
11-05-2011 09:25 AM
Chablonski
05-14-2010 12:55 AM
Jsmakr
07-16-2008 10:15 PM
MB
05-10-2005 06:18 AM
Crabby Guy
02-22-2003 11:04 PM
Quick Reply: Synchromesh on 2nd gear
