Suspension experts!
Old 06-12-2009, 12:11 AM
  #31
Paper Lawyer's Avatar
Originally Posted by Pie_n_Chips,Jun 12 2009, 07:50 AM
TBH I've never experienced neither in my old 01 or now, that floaty rear sensation that may take about on here and I'm no Ms Daisy.
Pie, it's on bumpy B roads that the inadequate damping becomes noticable, IME.
Old 06-12-2009, 12:38 AM
  #32
Pie_n_Chips's Avatar
Plenty of those round these parts
Old 06-12-2009, 01:02 AM
  #33
lucky77's Avatar
[QUOTE=Paper Lawyer,Jun 12 2009, 08:10 AM]I had no problems for 15K and I tracked the car probably 6-8 times with it lowered during that time.
Old 06-12-2009, 01:21 AM
  #34
I killed my buckets on OEM suspension - go figure
Old 06-12-2009, 03:40 AM
  #35
J_D
J_D's Avatar
Sorry about the measurment thng, could be arsed to get the tape measure
I know some people have got away with it in the past regarding the driveshaft spacers, but for what they cost I think its worth doing for piece of mind, becides its cheaper than new driveshafts.
Having driven both mine and an 08 spec S2000, the 1st thing I would do to the 08 spec S would be to change to coilovers and fit 99-01 spec ARB's followed by a bolt greasing session and a geo setup but thats just my opinion.
Old 06-12-2009, 04:39 AM
  #36
nigels's Avatar
Try these they have good reports so I bouight some but they have not arrived yet. You can have the ride standard all the way to slammed and the dampers are 30 way adjustable.
http://www.bc-racing.co.uk/vehicle-check.a...anID=6&modID=27
Spacers are an easy way to solve a problem but it can be done for free if you want to spend an hour or two under the car see the sticky in UTH theres a two hour reading on the subject! Im going to fit spacers, cost 99 quid.
Old 06-12-2009, 10:18 AM
  #37
S2000Si's Avatar
is that two people now saying that these are quite good?
https://www.s2ki.com/forums/index.php?showtopic=702766
sound like a bargain then to me?
p.s. what spring rates have you got?
Old 06-12-2009, 10:27 AM
  #38
Administrator
AquilaEagle's Avatar
Originally Posted by Fatbloke,Jun 10 2009, 10:09 PM
However, I still hate the mushy feel.
"Fatbloke"
Maybe that is the problem
just kidding
Old 06-12-2009, 01:04 PM
  #39
m1bjr's Avatar
You dont need spacers.
The only thing they change is where the rollers run on the buckets.
After lowering the central point will run a few mm further out that is all, nothing else.
Angles, loads etc etc will be unchanged.
Think about what they do, spacers?
Those who had vibes after lowering would have had them anyhow.
its not a function of lowering in itself.
If the buckets were already badly worn you'll get the vibes right away.
Once you pull a hub apart all becomes clear.
HTH?
Old 06-12-2009, 01:18 PM
  #40
Fatbloke's Avatar
Thanks everyone for the comments and advice.
Pie - thanks for the offer.
Nigels - BR coilovers are very much on the agenda.
AE - I'm just a bit big boned.
Quick Reply: Suspension experts!
