Suspension Bolts and Alignment
Just thought I share that I've just had the geometry set by the guys at WRC technologies, as recommended by someone on this board. I have to say so far I'm pleased with the results and they did an excellent job, but I won't really know until I get home and try the car on some roads I really know.
As for the suspension bolts I soaked them in PlusGas, then about a week later I took each bolt out, cleaned the bolt and greased them and the bush. Some were a bit difficult to remove but every bolt I took out had some form corrosion on it. I don't know if I was lucky and none were seized or if the Plusgas helped. For some of you that do have seized bolts plusgas might be worth a try.
Originally Posted by AquilaEagle,Mar 1 2006, 09:43 PM
Is plusgas like WD40?
I'd love to see pics of where these bolts and bushes are so I can be sure to look at them on my car!
Should be interesting to see how my 13 month old bolts look when I have them out over the weekend.
I have greased all suspension bolts from day1 - ideally, you should remove and grease the bolts but I just liberally coat with grease - stops ingress of water and moisture. Subsequently had no problems with the geo.
BTW - what did they charge you for the setup?
