Supercharged s2000 engine
#26
Member
Yep or you will be relying on the assumption you have fixed boost per rpm, which you generally do with a SC, but any belt slip and you will be overfuelling plus the MAP takes care of ambient changes in air pressure.
#27
I would be wary of any company that wants to tune a car with tps based tables on an application that isn't both na and using itbs. I would always use speed density for forced induction.
EDIT
Also a point worthy of note, on a traction drive supercharger like the rotrex, the temperature of the oil makes a difference to the amount of boost generated and from datalogs I have it can be as much as 2psi.
EDIT
#29
The F20C engine is such a tight install in the Westfield, because of the engines height, and the low bonnet line, that there's literally no room for the factory MAP sender - it's the highest point in a Westfield.
Obviously, it could be relocated. But apparently, Westfield have gone with TTS & Omex's advice that it (the MAP sender) won't be necessary.
