strut Brace + Fipk
strut Brace + Fipk
After buying and receiving a spoon strutt brace that I am over the moon with I have just fitted it:
Basically it is pushing down on the fipk heat shield rubber top and the plastic tube of the fipk.
Its up tight to the fipk, doubt it will do any damage but just to check will this be ok?
Anyone else had this issue?
Mike
Mike
Engine vibration may saw a hole in the intake unless you secure it somehow.
My setup is different and avoids this:
-- Chuck
-- Chuck
Mike, I picked up a Tanabe brace from a member on here some time ago and had the same issue, hence it's not on the car yet. Plan is to cut the FIPK surround down a bit and replace the rubber. Only needs a small trim.
UK Moderator
Or simply remove the strut brace, I doubt you'll be able to tell the difference.
FWIW I have a strut brace which is mostly useful for leaning on when topping up the oil.
