Struggling to find torque settings
Guys,
I've removed my front and rear shock absorbers to fit Eiabch springs and also the front upper arms from the chassis to allow me to remove the shock absorber However, I can't see the relevant torque settings when searching on the forum... any ideas? Or just yank them up?
G
G
Taken from the service manual
Shock absorbers
Upper bolts of the shock absorber: 49 N.m (5.0 kgt.m,36lbt.ft)
Lower bolt of the shock absorber: 6 4 N m (6.5 kgl.m,47 lbf.ftl
brake hose mounting bracket : 22 N.m (2.2k gf.m,1 6lbf.ftl
Upper arms
flange bolts: 9.8 N.m (1.0 kgf m.7.2lbf.ft)
lock pin:49-59 N.m {5.0-6.0 kgt m, 36-4:l lbl ft}
flange bolts: 132 N.m {13.5 kgf.m,97.6 lbf.ftl
Hope it helps
Chris
Shock absorbers
Upper arms
Hope it helps
Chris
Thanks Chris, sorted on the shock absorber. But still unclear as to the torque setting on the upper arm. I assume it's the flange bolt? It slides through the chassis, through the arm and bush and bolts into the nut welded onto the chassis lug??
I will try to find a link for you to download the service manual to have it
This link to a service manual download might work: http://download.dailyfreeware.net/do...163a2804e615aa
I can probably buy the manual on a DVD from ebay
UK Moderator
Originally Posted by lovegroova' timestamp='1358259694' post='22267972
This link to a service manual download might work: http://download.dail...e163a2804e615aa
Or see this thread https://www.s2ki.com/s2000/topic/991095-workshop-manual
