Strange throttle noise?
Old 07-16-2005, 01:01 PM
jimpom23's Avatar
Happens at the same point on the throttle lifting off too...
Will pop the lid back on the airbox and see if it makes a difference
TBW - Left speaker doesn't like to stay on when I go over bumps!
Old 07-16-2005, 01:16 PM
The Boy Wonder's Avatar
sounds like it needs some tape a la drivers side
Old 07-16-2005, 01:21 PM
Administrator
AquilaEagle's Avatar
I bet it is the CAI as per my 1st diagnosis
Old 07-16-2005, 01:32 PM
jimpom23's Avatar
AE - what can I do to remedy? I suppose if its just air coming in its not doing any harm
TBW - My thoughts exactly
Old 07-16-2005, 01:38 PM
its normal and sounds cool to me! (the intake noise....not the dodgy speaker!)
Old 07-16-2005, 01:44 PM
C7BLE's Avatar
f it is chirpy (like a high pitched ringing) then it's the clutch.
You can get your dealer to break your car in a fultile attempt to fix it or just get used to it.
Old 07-17-2005, 12:54 AM
jimpom23's Avatar
I've heard the 054 clutch whining on another S which is very much down the middle of the car for longer when no foot is on the pedal and revs are coming down - this noise is entirely throttle position specific, it only happens at a very exact position, in any gear, at any speed....
Old 07-17-2005, 01:23 AM
mikey k's Avatar
Seen as its my old car maybe I can help!
Never noticed any funny "sounds" out of it when I had it, but different people hear different things. It had a Spoon snorkel on it and a K&N filter. It did "whistle" at 8.5k rpm but that was normal with the Spoon on.
It has a 55 clutch not a 54, thoug it could be "ringing" in the gearbox/clutch?
ie air flow or rpm specific. More likely it is from having the airbox lid off I never ran it like that.
Old 07-17-2005, 01:47 AM
S2KPDQ's Avatar
The noise you are hearing is the clutch.
This is NOT the same as the clutch vibration on over-run below 4000rpm which is the clutch plate rattling - it doesn't matter wether you have the 054 or 055 clutch.
The fact that it happens under load at a specific speed is indicative of this issue
My S2000 does it as well...occasionally.
Nothing to worry about.
Andy
Old 07-17-2005, 02:01 AM
chris@vortech's Avatar
Is there any way of stopping the usual clutch plate rattling on overrun under 4000rpm as mine suffers from this?
Chris
Quick Reply: Strange throttle noise?
