Straight pipe
Old 08-05-2006, 04:04 AM
Amuse Boy's Avatar
Default Straight pipe
Those of you with a straight pipe (cat delete)...
Do you notice a change in sound high up in the rpm? Not just the tone change but a bit of a whoosh sound as you change gears? I have not noticed this with the cat on so I am attributing it to the de cat. Anyone else notice this slight whoosh/pssss noise?
All bolts and fitment has been checked. I noticed it when going through a tunnel. Thanks
Old 08-05-2006, 04:25 AM
MB
Member
MB's Avatar
Not really, but you have a different system to most (J's?)
Doesnt sound like much to worry about mate.
I notice a tone change - but no whoosh!
MB
Old 08-05-2006, 04:27 AM
cheshire_carper's Avatar
AB
maybe it's the sound of the engine switched on and rotating?
You don't hear it too often
Old 08-05-2006, 04:28 AM
MB
Member
MB's Avatar
A new one!
MB
Old 08-05-2006, 04:48 AM
Amuse Boy's Avatar
Thanks guys
I already found the answer - it's normal due to no heat shields on the de cat pipe. PL also noticed the same whoosh sound.
Old 08-05-2006, 05:07 AM
Paper Lawyer's Avatar
You just read my mind, that's amazing AB!
Old 08-05-2006, 06:26 AM
Trung_EP3CTR's Avatar
I had the slight 'whoosh/pssss' sound when I had the Toda manifold fitted.
Now it can't be heard, probably due to carbon build up.
Old 08-05-2006, 07:25 AM
Si2k's Avatar
Is this sound bad or good?
Old 08-05-2006, 07:37 AM
Kelk's Avatar
AB are you trying to imitate a dump valve and becoming more
Old 08-06-2006, 06:21 AM
Banned
gaddafi's Avatar
Quick Reply: Straight pipe
