Starting Up
Starting Up
When starting the car up there is an initial fan noise which lasts for a few minutes then goes off, the blower and/or A/C is not turned on so what is the noise?
Your car will rev higher when cold and at idle, it could be that.
How about popping your head under the bonnet just after you've started her up and have a look?
The air pump. For emmisions on start up. Makes a bit of a pop when it turns off after a couple of minutes. Noise should be coming from under the nearside headlight
Search for "Air pump" on this forum will give you more info.
TADTS
