srs light reset
http://nvsaudionj.blogspot.co.uk/201...ght-reset.html
1. connect clip to yellow clip, turn key to position II
2. wait for the light to go off and remove the paper clip/wire.
3. As soon as the light turns back on, quickly connect the circuit again.
4. The light should turn back off. Remove the paperclip/wire again.
5. The light will wait a second or two
6. 2 quick flashes and SRS light turns off completely.
6-A. two quick flashes and the light remains, you may be too slow or you have a short in your SRS somewhere.
7. turn off ignition and put back the clip.
8. wait 10 sec. then start the car. srs light should go out after 6 sec.
Im struggling with this.
I have followed the instructions and it doesnt seem to work.
The light goes out. Disconnect. Light comes on. Reconnect. 1 flash stays on.
Am i ment to do it with the yellow clip still attached to fuse board or is it ment to be dangling freely.
Why isnt anything simple.
dangling freely is ok
repeat process until it works
