Spoon Rad cap
#24
Originally Posted by lower,Dec 18 2007, 05:14 PM
The Koyo one looks like a radiator should look like.
Its the Honda one that make you go
It's only side on do you realise it's pathetic.
#25
Originally Posted by MB,Dec 18 2007, 04:25 PM
Sorry mate, maybe sounded a bit harsh.
It just read like you were thinking the new ECU was going to make the car work that much harder, that a new rad cap was needed! I still think you may be a bit dissapointed by the results from the ECU, so i'd do that first and see how you get on.
My logic was thinking that these may benefit the installation of the new ECU, ie the engine working harder if you know what i mean.
Yeah i know to begin with, that i wont get a massive bhp/torque increase from the ECU, but it's easy to get carried away with the BHP/torque figure when benefits can be had elsewhere like under the curve etc etc .
As i say it also to satisfy my interests and learn from such modifications.
#26
UK Moderator
The Mugen thermostat/fan switch/rad cap lower the engines normal operating temperature, from 93 deg C to 80 deg C (the Spoon setup lowers this even further).
Apparently, the standard ECU monitors engine water temp and uses this as one of the parameters (along with intake air temperature) to determine where it sets ignition advance - higher temps less advance, less power/torque.
AFAIK the Mugen runs a more agressive ignition map and thus the cooling mods are advised.
Chris.
Chris.
#28
#29
Member
Correct Chris.
Not sure on the ignition settings on the Mugen - that will be pretty much unknown, or a rumour from the US!
There isn't a huge scope to advance on an NA car between ECU's either.
#30
Stock ECU monitors temperature and when it detects higher temps then lowers the advance to protect the engine. This happens only in very hot climate conditions
Chris
