spoon air filter
spoon air filter
hi,
anyone know if these are good, bad or indifferent when fitted to the S?
http://www.spooneurope.com/html/products/i...t_airfilter.php
to be honest its just a replacement filter for the standard air box, and an expensive one at that, may sound different, but I cant imagine there would be a power gain as is usual with the S - You may do better spending the money on a proper CAI OR spend a lot less on a cheaper cone replacement KandN etc
I used the SPoon filter for a short time coupled with a Spoon replica snorkel. You'll definitely notice the sharper throttle response and a meatier intake noise.
*sorry that just conjured up some dodgy images in my head!
I think it did make a difference, but im bound to say that as I have one for sale. It was certainly better than the 9000 mile stock filter it replaced. I think paper/fibre filters are only at their best when new.
Paul
Paul
Just Fitted a Spoon Air Filter at my last service - Overall it does make for a crisper resonce + slight sound change.
More Bling-Bling I suppose, but it does look far better than the screwed up 'Cardbourd Box' that it is fitted as standard
Peter
Peter
If you guys are going to change to the Spoon filter - I would recomend you remove the L shape air thing underneath the lid and also cut down the partition inside the airbox down to 1 inch and then block off the resonator chamber at the back righ of the airbox with some thick plastic.
