Spark Plug Socket Size
5/8 sounds right, while the threaded portion of the spark plug is 14mm. I reckon the metric socket(16mm) will be fine too, albeit not as tight a fit on the spark plug, but at 18ft/lbs you won't be stripping anything.
No worries, but you really can use either a metric or imperial socket on the plugs, just make sure you thread the plugs in by hand first before you torque them down with the wrench - so as to avoid cross threading them.
Are the plugs not 10mm thread, but then 16mm across the flats to give the socket size? don't have one handy on the couch to check.
You mean 1/2" drive? 1" drive might be a little bigger. Glad you got it sorted and the seems like a good un.
