spark plug no 4..... how common is it that this comes loose?
I have heard guys comment on this being a common problem, is this so? does it need some kind of gasket/sealant to hold it in place? if not how often should it be re torqued? and does anyone know the torgue setting?
I have a 99 shape I will check the tightness of spark plug No. 4 tonight. did you get the head changed under warranty?
Or does anyone know if I can buy the new gaskets and swap them over....
cheers
cheers
Did your car have the spark plug/oil bolt recall? If not, I guess you'd better get it done.
Chaps - I'm assuming that this recall will be done on cars no longer in warranty given that it was a 'recall'?
Yes the head was changed under warranty. The oil bolt recall gave an extra years warranty on the engine. The recall on my old one was done at the same time as the head was changed. It was a MY00 BTW
