Space saver
Space saver
My son has just tried to use his spacesaver on his Mercedes to find that the bolts for his alloy wheels are too long for the steel wheel. Do I need special nuts for the Honda S2000?
So he's trying to use an S2000 spacesaver on a Mercedes? No it's not wrong nuts it's wrong car.
They're nuts.
Not the previous posters, the retainers on an S2000.
I understand that they are sufficiently 'hollow' in order to clamp a steel pressing against the hub and the facing profile is correctly-rounded. I carry a set of five, because the facing surfaces on my Mugen nuts are conical.
I presume M-B continues to use bolts to clamp the wheels to the hub. If they've not through-bored the hubs sufficiently (or the ABS ring is in the way) it's comical, not conical.
It’s clear enough
the s2000 has nuts, not bolts and wasnt designed by a German brummie so you’ll be fine
having said that i’ve never used one. My Panzervaggon has a compressor and gunk which i’ve never used. Had a slow puncture twice on that phukka
