Sounds like a Taxi
Sounds like a Taxi
Does anyone else find when they start there S it sounds like a Diesel, It seems to be just while it warms up but I would like to know if this is the case with all S.
Cheers Ant.
Cheers Ant.
Check you oil first. Does the sound go when you rev the engine, mine did this, got worse and worse, went from start up to all the time at idle, needed a new timing chain tensioner in the end.
I think AE had this Hopefully he will be along soon. Mine rattles a bit when cold. I believe its a bit of a Honda trait but they do loosen and I think there is something which can be adjusted.
I'd say mine was 'a bit tappety' but I expect they have been superceded !!
think AE may have had a bit more than the timing chain tensioner done under warranty if i remember rightly. Think he may have had the timing chain done as well. Very expensive job (this is what my local honda garage wanted to do first!!) I suggested they start with the tensioner and that fixed it all, thankfully!!!!!
Originally Posted by billybiker,Dec 5 2005, 06:38 PM
Mine's dead sweet right from the start. It revs slightly higher at tickover when cold but sounds like a well oiled sewing machine.
replacing the tensioners is part of the job. Ships, ha'p'orths of tar & stuff.
