Soft Top drain tank
Soft Top drain tank
Guys,
I need to get at and remove the passenger side drain tank for the soft top (dont ask), but the manual says the soft top assembly has to come off to get at it. Is this right, or is there an easier option? Its only the passenger side I need to get at.
Any help/suggestions welcomed.
Thanks
Thanks
If you remove all the plastic trim and the covers to the roof motors then you should get easier access to the drains.
It is best when the roof is off!
