Snooper radar
Snooper radar
Hopefully will be picking my s2000 up this week as long as DVLC have finally sorted my plate out !!! My question is , is it easy to fit my snooper to the dash ? I was thinking of using some velcro in the middle of the dash and running the cord down the side and into the electric point. Can I do this ok, I don't want wires hanging out everywhere?
I bought an S6R Neo - it's quite bulky so it's stick with suction cups to the windscreen resting on the dash against the driver's side windscreen pillar. The radar detector is in the middle of the screen just above the dash again stuck to screen with suction cups
Power lead is into a three way extension under dash on drivers side.
Hope this helps
Steve
Hope this helps
Steve
S6 Neo stuck to windscreen using suckers on RHS near dash. Radar/laser detector and GPS antenna stuck on dash in a central position near the base of the windscreen.
I fitted my S5 up 'just under' the rear view mirror and ran the wire up behind the mirror into the surround, down the side pillar and took power from the drivers footwell.
It suckers onto the windscreen and is perfectly positioned for easy viewing. inconspicuous too!
