slow puncture - repair or replace
Old 06-04-2004, 11:15 AM
Disorderly's Avatar
Default slow puncture - repair or replace
I've noticed the pressure had dropped on one of my rear tyres and on closer inspection have found a small screw stuck in the centre of the tyre.
Many people seem to think it will be ok to patch the tyre however, others have said that tyres with speed rating V and above should always be replaced.
Has anybody had any problems getting their tyres repaired.
The tyres are probably about 5mm so have plenty of life in them, but because they are worn, replacing one means replacing the other side to keep the car balanced.
Old 06-04-2004, 11:23 AM
Lurking Lawyer's Avatar
Repair should be OK, as I understand, if it's in the centre of the tyre - it's only when it gets towards the shoulder that tyre places refuse to repair it.
Old 06-04-2004, 11:29 AM
JMP
JMP's Avatar
Post a poll
Replace
Precision sportscar, perfect tyre essential
Old 06-04-2004, 11:42 AM
exceltoexcel's Avatar
You'll launch that plug within 2 weeks (if you actually drive your car) replace it. A repair should only cost ~$15 so you can chance it but when you launch the plug I'll be the first one to say I told you so.
Old 06-04-2004, 11:53 AM
Welshman's Avatar
Take it to a reputable tyre fitterand let them examine it. It'll either be pluggable or not. Suspect that with a screw rather than a smooth nail it won't be.
Old 06-04-2004, 12:00 PM
LLOYDJ's Avatar
I had a tyre plugged & lasted the life of the tyre with no hassle!!
Old 06-04-2004, 12:11 PM
euan's Avatar
I'd probably get it repaired if I could - but then I'm dead mean.
Old 06-04-2004, 01:55 PM
You're a Scot, Euan - that's a statement of the bleeding obvious!
Old 06-04-2004, 02:04 PM
eSeM's Avatar
Nah! it's because he is an accountant.
Old 06-04-2004, 02:40 PM
Busamav's Avatar
I would plug it , as Welshman says , take it somewhere reputable .
I got a puncture first day in my new S , went to Bracknell tyres expecting to be sold a new one and straight away they said no problem , under a tenner .
I would even run a plug in the rear tyre of a bike , not the front though.
Quick Reply: slow puncture - repair or replace
