Shaking?
Shaking?
After having the car lowered and being told that my front o/s lower arm is on its way out i have noticed that in second and third when i take a corner and foot it after in a straight line that the car shakes a bit.
Ive checked the wheels and had them balanced they are perfect.
Could this mean that the front arm has gone completely and needs changing??
Im not sure is a lower arm could cause this.
Cheers mark, any idea what they should be? I know again people havemixed opinions, i would say 32psi but not 100%.
Could the arm be causing this though mark as it does have life left in it but the rubber was starting to be visable but only by about 2-3mm.
your diff??
if it's under load.. it could be a buggered engine mount. a buggered drive shaft. how long does it last?
dan_uk
05-14-2010 04:55 PM
