servicing what do i need to know?
Hi all I'm wanting to go thru the car changing oils etc,the car has 54k on it and don't have reciepts of what was done and when so I'm gonna do a full service what would you do or what would Honda do.the things I have on my list is:
Oil change
Spark plugs
Rear diff oil
What else and what oils?
Thanks all!
Oil change
Spark plugs
Rear diff oil
Thanks all!
53 means transmission oil should have been changed by now, but if you want to be sure.....
Valve clearance aren't the easiest of Diys but if you are proficient with the spanners you can DIY. Search for a YouTube guide on this forum by ultranexus
Hi, check the FAQ for the service schedule.
Valve clearances aren't too bad; there's a video on Youtube that shows how to do it. If you're not mechanically competent, it's not something I'd recommend though.
If it were me:
Brake inspection (check discs for lips and pads for thickness)
Oil/Filter (ALWAYS use a Honda filter and tighten it up with the correct tool, Castrol Edge 5W-40/Motul X-Cess 5W-40)
Spark Plugs, these aren't cheap at a dealer (£80) but can be had on eBay for £40
Air filter (Unless you have an aftermarket intake, you may as well stick to an OEM filter)
Diff oil (the S only has a rear diff )
Gearbox oil
Brake fluid (RBF600)
Check the coolant, if discoloured, change it
Clutch fluid (RBF600)
Check tyres for wear/pressures, check the brand of tyres fitted, this makes a difference
Get the alignment/geo checked (plenty of info in the FAQ to tell you about potential problems)
Underseal
This will give you a VERY good base from which to start maintenance.
If you want any more info about the above, have a search...it's very useful and 99.9999% of topics have been covered.
Please refrain from using text speak as well
If it were me:
Gearbox oil
Underseal
That's the exact information I needed,just seen the vids on u tube and doesn't look too complex however il definatly be consulting my mechanicly minded friend,I did try and find the information I needed before asking but with little success,and also I do try not to use text speak but I'm a gordie so its how we talk up here haha however I will try my best in future.thank you again for the help
If it were me:
Oil/Filter and tighten it up with the correct tool, Castrol Edge 5W-40/Motul X-Cess 5W-40)
Gearbox oil
Underseal
If it were me:
Gearbox oil
Underseal
That will be the next stage,I am going to get the car on the ramp at some point and take the rust out from under the.rear bumper and from the transmission tunnel and re seal the lot.and then start replacing the bolts which are rusted or may give me problems in the future
JS2k.com
51
06-30-2009 08:49 AM
msmokie
72
04-24-2009 07:09 AM
