Serious, serious engine problem
Old 07-24-2011, 07:41 AM
  #21
MB
Member
MB's Avatar
It's very easy to ever rev it, just go from 6th gear to 2nd and you will be doing 3 zillion rpm. The electronic limiter does nothing for you then. Kaboom. Or often delayed kaboom.
Old 07-24-2011, 08:14 AM
  #22
Cudder's Avatar
I never miss gears though, I read on here thar it can do damage so I've always made a point of not skipping gears, going up or down the box.
Old 07-24-2011, 08:27 AM
  #23
Nick Graves's Avatar
It's a secondhand car though.
For people who do stupid things like downchange mid-corner, it's very easy to go from 5th to 2nd. Ask EP3/EM3 owners!
Although that normally causes interference between valves & pistons & the conred exits stage right.
Your symptoms (run crank bearings) are more associated with the Bad Oil Blues.
Old 07-24-2011, 09:02 AM
  #24
Cudder's Avatar
True, no one knows how it's been treated in the past. I know I've been vague with what the problem is but does anyone know if its an expensive fix?
Old 07-24-2011, 09:45 AM
  #25
Banned
rob2.2's Avatar
have they compression tested each cylinder? that will give you a pretty good idea to which bearing has failed if its a faulty big end.
please keep us informed as be interesting to see if it has suffered similar problems to mine did.
if they offer to re-build it because of a failed big end be cautious of debris from it being thrown around the engine oil ways by the oil pump and make sure they replace the oil pump with a brand new one. dont want them to rebuild it then have some debris in a oil gallery to clog it up and make it go pop again.
Mr-T
06-26-2014 09:01 AM
macr88
Engine
01-21-2010 11:22 AM
heart
11-23-2007 01:37 PM
Quick Reply: Serious, serious engine problem
