Secondary air pump
Secondary air pump
Engine management light is on on my s2000 showing up air pump short of power. Would this be a problem wit relay? Or would I need to follow power supply back to try find a break
I would take this as an opportuiny to remove the whole lot - Winfreak does a kit with a resistor.
But it sounds like an air leak to me, does it sound excessively loud (like a hoover) on start up ? What code is being thrown - there is a specific relay code, an air volume code and a pump code - that will help you track it down.
Deres a box wit a fuse in it down at air pump but dat fuse is fine if dats the one your thinking of?? Not sure if pump is working or not I'll whip bumper off tonite and see if it's actually doing anything
50/50 weight distribution is destroyed the second you get in the car - and can you tell the difference with 5kg of shopping in the boot?
5kg is neither here nor there unless you're in competitive Motorsport.
