Screech on cold wet startup?
Old 02-07-2012, 01:18 AM
jammer2209's Avatar
+1 for starter motor
Old 02-07-2012, 01:54 AM
simonix's Avatar
Why would the starter motor still make a noise after the engine has started and speed up when the revs raise?
Old 02-07-2012, 03:29 AM
UK Moderator
UK Moderator
lovegroova's Avatar
If it's doing that, then it's not the starter motor. The starter motor makes a brief crunch (like you've accidentally pressed the button for too long) and then it goes away.
Old 02-07-2012, 04:14 AM
AndyL's Avatar
Possibly the starter gear is engaging, but not disengaging fully when the starter button is released, so the engine is actually driving the motor, hence the noise?
Old 02-07-2012, 04:24 AM
Jonesybubs's Avatar
Originally Posted by lovegroova
A noise from the starter motor is very common in the cold. Mines been doing it for years now.
mine has been doing it for a while
Old 02-07-2012, 05:02 AM
crispyshark's Avatar
mine's just started doing it too...glad someone brought it up as i was beginning to wonder if i was going to have to spend even more money in addition to the new hood, rust on the wheel arch and new brakes!!!
I do this out of love i'm sure....sanity, no!
Old 02-07-2012, 08:22 AM
CHIPPO's Avatar
Sounds mad but if the aux multi V belt try a small blob of grease on the V's. Same with old fashioned V belts.
Old 02-07-2012, 09:03 AM
sata3000's Avatar
Your belt
Sent from my SPH-D710 using Tapatalk
Old 02-07-2012, 09:13 AM
Nick Graves's Avatar
Since there's an auto-tensioner (makes changing it easy!) your belt shouldn't be screeching like an old Astravan & needs changing urgently.
Mind you, the bearing on the autotensioner can screech if it goes dry - usually at high RPM & WD40 makes it go away.
Old 02-07-2012, 09:32 AM
sanchez's Avatar
Thanks for all the help guys, just wanted to narrow down the list of possibilities, i think that its the belt, car has done 76k now, so will change that first, and go from there
Quick Reply: Screech on cold wet startup?
