Scratched centre piece?
#21
Ok so I gave it a go and its turned out ok, I created another smaller scratch in the process but its hardly noticeable. I havent managed to get a pic of it fitted as im currently a bit nocturnal. There were 2 fixings that were glued in placed or more so moulded, I just drilled these gently with an 8mm drill bit. Then it was a crosshead screwdriver to undo the 2 screws holding it then a flat blade screwdriver to unclip the other 6 clips.
I used any old paint stripper and it worked fine, I did have to do about 3 layers thou to get all of it off. I think I really need to do a forth as ive noticed a few specs still there since.
I'll try and get an install piccy in the next couple of days
Hope this helps
Hope this helps
#26
Thats not metal (thou it looks like it), its plastic. If it gets scratched again then i'll respray it carefully then use laquer for now I like to look at it as a 2nd free chance prior to painting and possibly bodging
#28
Cheers for the tip. I have a few specs left where it needs a going over once more. Rather than me taking it all apart again I may give the surgical route a try, i'll let u know how I get on
