Scanguage
Originally Posted by Ajs_s2k' date='Jan 2 2009, 08:35 PM
Nice work, how do you find the scan guage for showing accurate Uk MPG?
I do have current MPG on the guage at the moment but it's so up and down when driving around town that its just a funny number switching between 7mpg and 9999mpg
I'm planning to add the xGuage bits to put some of the average MPGs into the guages.
Originally Posted by NineBolts' date='Jan 2 2009, 09:43 PM
might just set it up for litres... I want it for monitoring temperatures and If I can get it to estimate distance to empty that is also good.
Must have been difficult to cut the aperture and button holes so accurately.
Nice work
You could cover the back with some black felt. Velcro top and bottom would hold it in place.
Watch out for the Scanguage draining your battery. I have had to unplug mine as it was turning itself on randomly.
I walked past the car in the drive one evening to find it glowing and when the car was left for a couple of days the battery needed re-charging.
Nice work
Hey, about time!
Nice job, compliments
FWIW Im also finding averages are good and accurate, I run in litres as its easy at fill up time.
I've created two Xgauges called 2MT (distance to empty) and AVG (Average daily fuel consumption).
Also made a spare lead, using a
Theres a dead band adjustment that will stop the off scale 9999 reading happening.
You read the TPS (throttle position sensor) raw value on screen at throttle almost closed and feed into the cutoff parameter in SETUP.
It then ignores readings for averages and instantaneous fuel consumption at closed throttle on the overrun which generate these nonsense numbers and slew the average readings.
HTH.
Originally Posted by Boab01' date='Jan 2 2009, 08:02 PM
That's nice would love to see a how to.
Looks a nighmare to get the holes cut int the right place without making a b*llocks of the door.
Looks really good.
Originally Posted by johnbuck' date='Jan 2 2009, 11:26 PM
I agree.
Looks really good.
Looks really good.
