Sat Nav bezel
Old 03-27-2010, 04:24 AM
S2000_FUN's Avatar
[QUOTE=barefoot,Mar 27 2010, 04:18 AM] S2000 You might be right there I will cut a hole to find out if it is there then a template would help still not that easy to cut a precise hole as a bit of guess work would be involved and there is not a lot of room for error.
Old 03-27-2010, 04:26 AM
barefoot's Avatar
Yeah could you do that for me did you use the Honda bezel like mine? If so how did you attach your screen to it?
Kev
Old 03-27-2010, 04:37 AM
S2000_FUN's Avatar
I used the OEM bezel like the one in your poto. The screen was clued behind the bezel. You just have to find the right size screen to fit in the whole bezel. The only bad thing when you glue it behind the bezel (can't see any other option) is that it does not leave to much room in the bezel to strech. If you understand what i mean, plastic bezel can strech a bit, but with the screen behind cannot strech much. We tried to glue it with silicon on the dash but this has failed cause the bezel could not strech a lot to become one piece with the dash so with the time it has fallen off. Tomorrow i will remove the screen to get it glue with a real glue so i will be able to get your measurements.
I have to leave now so if you do have more questions feel free to ask and i will reply as soon as i get back
Chris
Old 03-27-2010, 05:22 AM
Dan Hale's Avatar
PM Grittyshaker - I'm pretty sure his is a JDM with sat nav.
Old 03-27-2010, 06:11 AM
Nick Graves's Avatar
Originally Posted by chrisr111,Mar 27 2010, 11:18 AM
If you are not going to take the dash out you need to cut a smaller pilot hole so that you can locate where the bezel clips in and then cut a larger hole in the correct position.
There are no templates available AFAIK.
Chris.
That's what I did in the Prelude's headlining, in order to install the USDM overhead light console round the mirror.
Old 03-27-2010, 09:56 AM
The Loon's Avatar
This is THE definitive thread.....
https://www.s2ki.com/forums/index.php?showt...0&#entry2085260
Welcome to the Dash Cutting Club
mattie170
07-19-2012 06:44 AM
wanderingmag
09-02-2011 01:03 PM
icecreamballer
09-02-2005 09:57 PM
S2KCHAD
02-10-2004 06:33 AM
Luwin1026
11-13-2003 08:40 PM
Quick Reply: Sat Nav bezel
