s2k bullet proof engine.... what boll@%
Banned
Originally posted by bert_smith
I have had the car for over 2 years now.
It is 3.5 years old ish (jap import and out of warranty period anyway)
Have all recalls been done?
W6DAN what concerns me is that on average over 3 years you'd do 36,000miles by which time I'd expect any niggles to be ironed out....mine will have done around half the expected mileage over 3 years and it will be just my luck for something to go pop just as the warranty runs out
The misfire/loss of compression symptom could relate to the known issue of the initial spark plug design working loose over time. As a JDM car it would likely not have been covered by the Honda recall program... might be worth investigating as Honda might cover it as a good will gesture given the known design issue...
Tif
Tif
Banned
Tif
Tif
How you doing mate? Not seen you around for a while.
Pete
Find out what the problem is first. Can't plan till you know what's wrong. If the worst does happen, you can get an engine from a UK breakers. One warning - you may need the Loom/ECU, as there are a couple of differences in the sensors at least between JDM and US. So I'd presume a UK engine, may not just drop in - not a big issue though.
-Brian.
-Brian.
