S2000_Europe went to the Dyno
Hi Folks
finally I went to the dyno to see if my butt dyno is right
Here you have the curve before the Supercharger with Aftercooler, HP are measure at the flywheel.
NA
HKS Exhasut, DC Sport Ceramic Header, 4:44 final ratio
Powered by Comptech
the as above with Comptech SC and Aftercooler
NA
Powered by Comptech
Green mean power loss due to the traction...
at the end of the RPM range (7500- 9000) we had some problems becasue the car started to slippered, So we wet the tire with sugar&water and I sat on the trunk!!!!
"butt dyno" says wooooooooooooow!!!
The car is easy to drive, like haveing a 6 clynder engine.
people at the dyno told that the car is runnig very lean 14,7:1 A/F ratio:
1. I checked the plugs and they were a bit dark = Rich mixture
2. I call Comptech and told them the they measure the Co2 emission using a sonda on one tialpipe.......... Joe told me to buy a wideband and measure the A/F ratio, becuase the way that the measure is not very accurate:
2.1 I have two tial pipe
2.2 I sould see the mix before cat to get the right measure.
I will get he wideband by the end of this week, I will keep you posted.
