S2000 PCD
S2000 PCD
not sure if this has been covered already im sure it probably has but i done a search & couldnt find anything, what is the PCD for a s2k, i.e tegs preludes are 4 or 5 x 114.3, civics etc normally 4 or 5 x 100.
cheers in advance
cheers in advance
Originally Posted by Bibbs,May 16 2009, 05:01 AM
5 x 114.3, same as rx7, supra, mr2 etc. It also has staggered wheels, fronts smaller with diff offset.
sorry to be a pain but what is the best offset to run along with size of tyres?
i want to come down to either 18's or 17's, going to be running on on r888's or ao48's
17" wheels are the most suited to the S
Tyre sizes are upto you. I run OEM sizes:
7.5" wheel on the front with a 215/45/17 tyre - T1R (offset +45)
8" wheel on the rear with a 245/40/17 tyre -T1R (offset + 48)
The offset again is up to you. The offset I have on both wheels are IMO the lowest you should go.
7.5" wheel on the front with a 215/40/17 tyre - T1R (offset +45)
8" wheel on the rear with a 245/45/17 tyre -T1R (offset + 48)
what would happen if i went for a bigger offset?
ive been looking at rotas. biggest i see are 17x8.5 for rear & 17x7.5 for front, i was wantin a wider wheel sif possible but cant see any sizes wider.
Originally Posted by YumYumTurbo,May 17 2009, 07:39 PM
awesum, cheers for that mate.
If you go with a lower offset the wheels will stick further out from the hub. Meaning if you lower the car, the wheels will hit the arches. So you would have to roll them.
If you don't lower the car they would look shite aswell. When lowering you add camber which will tuck the wheels into the arches
Here you go. I've just got this pic from the US forum.
It shows you what a low offset wheel looks like on the S..........Shat.
Stick with 45+ matey.
P:S Don't go to wide with the wheel width either
