S2000 emblem removal and fitting
Hi all
I was thinking to remove the S2000 badge on the wing to spray it an anthracite/gunmetal colour to match my wheels and also ditch the little Honda badge above it.
To remove am I right in thinking just a heat gun and leverage to remove the badge and glue remover to get rid of the gunk?
but to re-fit, is there a special type of glue to use so not to damage paintwork if I want to remove again? or should I play safe and just use double sided tape and cut it out with a craft knife? anyone done this before?
Thanks
Thanks
Before you decide to do this please search removing s2000 emblem. The Honda bit is easy. The s2000 is a giant pain in the arse. It takes ages and is very difficult. I used hair driers wd40 and it was still almost impossible. Read the woes of other people before taking the s2000 bit off. After all this I would recommend instead painting it whilst on the car.
