S02's
Old 12-20-2004, 07:35 AM
moff's Avatar
Default S02's
After reading the current tyre thread, I am really confused why our S02's have 225 on the side of them when they are actually 245's?
Whats the reasoning behind this? This must cause loads of problems when drivers changing tyre brands simply read the exisiting measurements from the side of the tyre wall and don't use this site.
Old 12-20-2004, 07:41 AM
Richieh's Avatar
They're not 245s, but the structure of the tyre means the tread in contact with the ground is the equivalent of a 245 tyre.
Old 12-20-2004, 08:40 AM
dws2000's Avatar
I'm confused, how does that work..
Old 12-20-2004, 08:48 AM
Banned
Bada Bing!'s Avatar
My guess has always been that because they have a tougher sidewall that the tyre doesn't squat and spread out like other tyres, so they made it a bit wider as a result.
Could be way off though.
Old 12-20-2004, 08:49 AM
GTFCTIM's Avatar
Puzzles me too.
I think that the size of the grooves are smaller on the S02, so therefore there is more rubber actually touching the road than on a normal 225, and it is the same amount of rubber as on a 245.
Old 12-20-2004, 08:51 AM
Ruckus's Avatar
There are other 225 that are even wider than the S02's
Most time i have seen this is when tyre's are OE, ie the Pzero's on some porsche etc
Old 12-20-2004, 12:59 PM
moff's Avatar
Weird... still confused
Old 12-20-2004, 01:02 PM
Bassoctopus's Avatar
Although the stiffer sidewalls also mean that the edge of the tyre is more of a right angle meaning that there is more rubber on the road.
Old 12-20-2004, 02:59 PM
Shiskine's Avatar
Must say I find all the tyre threads more confusing than they are enlightening ... and it explains why I stuck to the OEM tyres when replacing my rears two months ago.
Are we saying definitively that, unless you go for the OEM SO2s, you always go for 245s in any other (rear) tyre brand? Similarly, do we step up on the fronts from 205s to 225s?
I think the thing that worries me is that simply because AN Other board member has fitted a particular tyre to the car, doesn't mean it's correct.
Shisky
Old 12-20-2004, 11:25 PM
euan's Avatar
Some people prefer the 225's on the rear, and you don't go for the bigger size on the fronts for some reason - I guess because the impact of less rubber on the road is much reduced since there is no power going through them.
Quick Reply: S02's
