Rubber seal detached from roof frame
Old 09-28-2009 | 03:24 AM
FistralG's Avatar
Question Rubber seal detached from roof frame
I've just noticed that the rubber seal has detached from the roof frame just behind the drivers side window.
Any suggestions as to how I should go about repairing it, bearing in mind that its an MY07 with only 11K miles?
Old 09-28-2009 | 04:10 AM
mikey k's Avatar
They do just clip over the metal carrier.
Give us a pic
Or take it to the dealer
Old 09-28-2009 | 04:16 AM
FistralG's Avatar
Give us a pic
Thanks Mike. It looks like its torn away from the metal frame there are bits of foam still stuck to the metal.
I'll try an get a pic and post later.
The dealer was my 2nd thought. But if its a simple case of glueing it back on I think I could do that myself. I wasn't sure what glue I should use or how long it would last. I'm also concerned that any attempt at a DIY repair may affect any warranty claim I may have.
Maybe the dealer is the best option.
Old 09-28-2009 | 04:19 AM
Stufix's Avatar
Just logged in to ask almost exactly the same question.
The rubber seal at the top of the door is coming away from the metal carrier. I spent about a hour yesterday trying to get it back in without success.
Is there a knack that I haven't quite mastered?
Old 09-28-2009 | 04:32 AM
mikey k's Avatar
When the search is back up
There are some excellent pictures posted recently of the same problem.
I took mine off the other week to cure a leak.
There is some foam behind it but it does not seem to hold the seal on.
Old 09-28-2009 | 04:40 AM
Spies's Avatar
Foam is there to help seal it against water, if its not there or brittle it will let water in.
taffyb
12-23-2009 04:35 AM
taffyb
02-09-2008 08:10 AM
Shopman
08-19-2006 10:35 AM
blakpawn
06-28-2005 06:25 AM
Squeezer
04-17-2003 03:08 PM
Quick Reply: Rubber seal detached from roof frame
