Roof problem....
Old 03-04-2003, 07:33 AM
Ali_McBlue's Avatar
Originally posted by NEED4SPEED
This has been discussed before. The vinyl roof can be quite stiff when the temperature is low and will not fold as easily as when it is warm. Some people on the board have suggested turning the heat up in the cabin for 10 minutes and then lower the roof. HTH
Thanks N4S - turns out it is just a "cold" problem.
Phew - I hate going to dealers - they are always so condescending!
Old 03-04-2003, 07:56 AM
Amuse Boy's Avatar
Glad to help....
Old 03-05-2003, 12:24 AM
Administrator
AquilaEagle's Avatar
Its only ever done this to me in the cold, Its something to do with the tension in the cold or something (I used to love physics, but long time since i did it, otherwise i could prolly explain it!)
Old 03-06-2003, 12:24 AM
Alison_Ruck's Avatar
Thanks for all the advice.....now I've got to decide which Honda to take it to. Maidstone or Ashford. Hmmmmmm, do you think they will charge me to look at it? Don't know if the roof comes under the warrenty or not?
Cheers
A
Old 03-06-2003, 12:35 AM
SilverShark's Avatar
Good luck - they will not charge you as all work would be carried out under warranty.
I too had pervious problems with my roof, the rubber seals were replaced as I had a shower whenever I used to get into the car after it had rained !!!
Old 05-30-2009, 12:10 PM
Sith's Avatar
Hello guys! Actualy I know whats the probliem is... Change the small springs between two centre bars. You can find those springs on each side... If somebody needs more info- write to me... I will explain, or maybe even put pictures! I found and solve that problem myself
Old 05-30-2009, 12:14 PM
motogp1's Avatar
6 years later
Cardiff
01-24-2012 06:43 AM
s2konroids
11-28-2008 02:36 PM
blacks2k
12-07-2005 12:25 PM
hlau
06-14-2005 05:51 PM
Tyringe
03-01-2002 12:38 AM
Quick Reply: Roof problem....
