Reverse Gear
Old 07-30-2011 | 09:59 AM
keith2.2's Avatar
Default Reverse Gear
Car was working absolutely fine this morning - I reverse parked at lunchtime, then when I first went to 5th after leaving lunch, the lever went right to the right-hand-side of the gate.
I drove home and had to use some care shifting into 5th and 6th.
All gears, including reverse, are working. It seems I just no longer have to push the lever down to get into the position for 5th.
Three questions really:
Does anyone have a diagram of the shifter mechanism so I can see if there's anything obvious that has come loose?
Has anyone come across this before?
..and hence does anyone have a specific fix?
Thanks
Keith
Old 07-30-2011 | 12:46 PM
Nick Graves's Avatar
Hold on, you don't need to push down for 5th - only reverse.
There is a detent pin (visible if you look down the hole where you shaft normally goes ). I wonder if yours has come adrift?
Old 07-30-2011 | 12:49 PM
keith2.2's Avatar
Ha you know exactly what I mean, Nick
I shall take a look when I get back later this week.
I think I'm confused because I can't visualise the mechanism, and don't get how it's going into reverse fine without needing to be pushed down. I'm sure it's quite clear really!
Old 07-30-2011 | 01:05 PM
Si2k's Avatar
My spare box thats in the garage is stuck down on the gearstick, I can't get it into 6th unless i pull the stick up out of the box.
Sounds like your stick is stuck ? Easy enough to get out and have a look
SlideWayz
08-26-2012 05:19 PM
dievoche
12-16-2010 12:56 PM
Tuan85
05-16-2009 03:24 AM
intcoverup
05-05-2007 10:45 AM
Rx man
01-19-2002 08:37 AM
