rev problem
rev problem
im having a weird problem, i sometimes come to a stop and its idling about 2000rpm and sometimes its around 500 rpm.
if its at 2000rpm i'll give it a little rev and it'll fall back to 500rpm.
the revs seem to drop really slowly to, unless i rag the crap out of it.
i've cleaned the throttle bodie with carb cleaner, tightend my throttle cable tried to clean the IAC but could get the damn thing off.
its seems that the metal bit the throttle cable attaches to doesnt go back to the fully closed position, and when its stuck at 2000rpm i can physically push it back a tiny bit and it'll lower the revs. its as if its getting slightly stuck.
im wondering if a new spring and metal thingy (sorry dont usually have anything to do with fixing cars) would sort the problem? anyone know part numbers and prices?
Any suggestions to the problem?
pic below to show the "metal thingy" lol
The metal thingy is the throttle butterfly I think?
Mine does the same thing but only on startup. It seems fine after I've driven it for a bit. Haven't really thought about why it does it. I just assumed it did it because the engine was cold.
mine does it all the time though, its really anoying me.
i'll come to a round-a-bout and change gear, but the revs will be stuck at 3000rmp so i look like a tit, and im burning my clutch!
try wd40 on the butterfly first ans the cable should be locked at one end meaning only the joints will be libricated. otherwise strip the assembly down and copper grease the bolts and the lubricate on reinstallation.
right will strip it down and put copper grease on it then and try that.
im sure one of hooks on my spring has snapped at some point though, so i wana buy a new spring and metal thingy. Dont suppose anyone knows the part numbers?
Best of luck, there a user manual to downlod somewhere on here, think the yanks have it in PDF format.
Best of luck, you can always ring a breakers for bits.
Does anyone know how often you should lube the mechnism and wire?, and what with?
cheers
cheers
For lubricating throttle linkages, I either use GT85 (has PTFE in it) or a Spray DRY lube. Trouble with wet lubes (WD40 etc) is that because it's wet, dirt and dust stick to it, and accelerate the problem. ( See what I did there ?!)
I clean and lube linkages with every service, but it's personal preferance.
