Reset SRS light
Old 01-30-2010, 04:04 AM
buaan's Avatar
Default Reset SRS light
Hello guys,
The problem, I pulled the bloody 10amp SRS fuse out instead of the 15amp fuel pump fuse when doing a compression test (thinking that I could remember the procedure off the top of my head)... I also flattened my battery in the process and had cack results due to fuel in the compression chamber D'oh... amateur moves.. total waste of time.
Anyway, I now have a solid SRS light on my dash.
All the threads I've found are all stating different methods, pull battery neg, paper clip in some SRS connector, obd2 code reader reset, etc etc. No definitive method.
If you have the time can someone give me a clear method of reseting that is tried and tested
I know theres not a problem with the system, but I don't like the idea of driving around with the light on as I'm paranoid the system will fail in a crash.
Thanks all!
Old 01-30-2010, 04:41 AM
GiffS2K's Avatar
Have you done an ECU reset?
Old 01-30-2010, 04:52 AM
buaan's Avatar
Affirmative, right bank of fuses, 7.5amp fuse, 2 mins. Light still on.
Old 01-30-2010, 08:34 AM
buaan's Avatar
Just tried an obd2 reader, no codes.
Anyone know the proceedure for putting a paperclip in the srs plug?
I hate having warning lights on my dash haha
Old 01-30-2010, 09:09 AM
m1bjr's Avatar
http://www.honda-acura.net/forums/sh...d.php?t=243612
Might help - you need to find the correct harness (reset) plug under the dash though
The SRS computer is totally separate from the ECU so you wont get codes from your ECU reading.
Old 01-30-2010, 09:19 AM
buaan's Avatar
Right, excellent I'm sure I saw the connector location in the service manual.
I'll have a bash at it tomorrow.
Old 01-30-2010, 10:52 AM
veehexx's Avatar
srs reset in my sig...
edit: ignore that - picture in the post is no longer valid!
vinny
11-30-2010 12:24 PM
S2KVITO
08-09-2010 08:03 AM
LTB
10-24-2007 06:25 AM
DERF
12-14-2006 06:22 PM
s2konroids
10-16-2006 01:15 PM
Quick Reply: Reset SRS light
