replacing rear light lenses
Old 07-24-2014 | 11:50 PM
b000n's Avatar
Default replacing rear light lenses
I have just purchased some ap2 rear lights for my s2k , and the clear lenses are slightly cracked and scratched ..
Is it possible to replace the lenses as I have my ap1 lights left over ..
Or can the cracks be fixed ( which I think is unlikely )
Thanks
Old 07-25-2014 | 01:21 AM
heymynameismark's Avatar
I'm not sure if pre and facelift lenses are the same? But in theory, yes they can. It'd be a case of warming the sealant up in the oven, or similar, to soften and then pry apart. Then replace with other lense and re-seal.
Old 07-25-2014 | 02:37 AM
b000n's Avatar
Ok, I think they are the same shape on inspection , I'll give it a go
Old 07-25-2014 | 05:13 AM
e130dan's Avatar
Can you not wet and dry out the scratches then polish it out? I was going to try and take my lights apart but apparently they crack really easily and are a pain to put back together.
Old 07-25-2014 | 10:30 AM
GreenmanS2000's Avatar
You know you need to cut the bodywork to fit the later style lights...
Old 07-25-2014 | 01:09 PM
loftust's Avatar
Correctomundo.
Sent from my GT-I9300 using Tapatalk
Old 07-25-2014 | 01:21 PM
AndyL's Avatar
Yep you certainly do - like this:
There are other less tidy ways of doing it.
Old 07-26-2014 | 09:49 AM
b000n's Avatar
Yes I do know you have to cut the body work , but I'm happy to go ahead with it ... And it's more cracks than scratches
Nicroman
02-28-2014 04:11 AM
SCZ4
05-19-2013 08:42 AM
r8byb
02-20-2011 12:49 PM
falcone
07-21-2006 07:00 AM
j5669
03-23-2006 08:23 PM
Quick Reply: replacing rear light lenses
